Thickness property
Sets or returns the thickness of an object. The thickness specifies the distance a 2D object is extruded above or below its elevation
Syntax
DoubleVariable = object.Thickness
object.Thickness = <double>
Where:
     DoubleVariable is a double-precision variable representing the thickness;
     Object is an Arc, Circle, Line, Point, Polyline, Solid, Text, or Trace object.
Examples...
Thickness property example
