bim:get-assigned-building
(bim:get-assigned-building
ename)
Returns the building name, to which the given
entity is assigned to, or NIL if that entity is not assigned to a
building object.
Arguments |
ename the entity to query, as normal entity or as VLA object name |
Return |
the building name (as string), or NIL if the entity is not assigned to a building object |
Example |
(bim:set-assigned-building
ent "Building 1") T |
Remarks |
