bim:set-assigned-building
(bim:set-assigned-building ename
building)
Assigns the given entity to the specified
building.
Arguments |
ename the entity to be assigned, as normal entity or as
VLA object name |
Return |
T if successful, or NIL in case of an error (like, building does not exist) |
Example |
(bim:set-assigned-building ent "Building 1") T |
Remarks |
see (bim:get-assigned-building); |
