bim:has-material
(bim:has-material  name  [ global ])
This function verifies whether the specified BIM material exists in the document library (default), or in the global library.
Arguments
name  (string) the case-sensitive name of the material to be verified
global  (optional, default NIL) if 'global' is specified and non-NIL, the material is verified against the global database, otherwise verified against  the document-specific library
Return
T if the specified material exists in the particular library, NIL otherwise
Example
(bim:has-material "Bronze")   T
(bim:has-material "Bronze" T)  T
(bim:has-material "Paper")  NIL
(bim:has-material "Paper"  T)  NIL
Remarks
the material name is case-sensitive !
©  Bricsys NV. All rights reserved.
