bim:save-material
(bim:save-material name  data  [ global ])
This function saves the material definition under the specified material name, in the document library (default), or in the global library.
Arguments
name  (string) the case-sensitive name of the material to be saved (priority over the material name as specified in data list)
data  (assoc list) the material parameters list in the format as returned by the (bim:get-material) function
global  (optional, default NIL) if 'global' is specified and non-NIL, the material is saved in the global database, otherwise saved in the document-specific library
Return
T if the save operation was successful, NIL otherwise
Example
(setq data (bim:get-material "Gold"))
(("Name" . "Gold") ("Desc" . "") ("Comment" . "") ("Appearance" . "Gold") ("CH_Name" . "ANSI31") ("CH_Scale" . 1.0) ("CH_Angle" . 0.0) ("CH_Cross" . 0) ("CH_Anno" . 0) ("CH_Type" . 1) ("SH_Name" . "SOLID") ("SH_Scale" . 1.0) ("SH_Angle" . 0.0) ("SH_Cross" . 0) ("SH_Anno" . 0) ("SH_Type" . 1))
(setq data (subst (cons "CH_Scale" 2.0) (assoc "CH_Scale" data) data))
(("Name" . "Gold") ("Desc" . "") ("Comment" . "") ("Appearance" . "Gold") ("CH_Name" . "ANSI31") ("CH_Scale" . 2.0) ("CH_Angle" . 0.0) ("CH_Cross" . 0) ("CH_Anno" . 0) ("CH_Type" . 1) ("SH_Name" . "SOLID") ("SH_Scale" . 1.0) ("SH_Angle" . 0.0) ("SH_Cross" . 0) ("SH_Anno" . 0) ("SH_Type" . 1))
(bim:save-material "Gold_2" data)  T
Remarks
the structure of the data list must be the same as retrieved by the (bim:get-material) function;
the specified name has priority over the name as specified in ("Name" . name);
the material name and all parameter values are case-sensitive !
©  Bricsys NV. All rights reserved.
