bim:ifc-exportfile
(bim:ifc-exportfile filename [
options [ entities ]])
This function exports all or specified
entities as IFC file.
Arguments
filename (string) the name of the IFC file to be
created
options (integer) export options flags (combination of bit
values); if omitted or 0, default IFC export options (see Settings)
are used
1 export BaseQuantities
2 export entities on frozen & off
layers
4 explode external references
8 export MultiPlies as aggregated
objects
// these flags specify the target IFC version,
exclusively, only 1 of these values can be used :
16 IFC2x3
32 IFC4
48 IFC4x1
entities (list) optional, list of ENAMEs, specifies the
entities to be exported; if omitted or NIL, all entities are
exported
Return
T, if the IFC file is
successfully created, or NILotherwise
Example
(bim:ifc-exportFile
"D:/Test.ifc" (+ 1 2 4 16)) creates IFC2x3 file,
including entities on frozen + off layers
(bim:ifc-exportFile "D:/Test.ifc" (+ 1 4 32))
creates IC4 file, excludes
Remarks
