bim:ifc-importfile
(bim:ifc-importfile  filename  [ options ])
This function imports the specified IFC file into the current drawing.
Arguments
filename  (string) the name of the IFC file to be imported
options  (integer) import options flags (combination of bit values); if omitted or 0, default IFC import options (see Settings) are used
1   import Bim Data
2   import IFC Space
4   import Parametric Components
8   import Project Structure as Xrefs
16  import Brep Geometry as Meshes
32  import using SubDMesh entities
64  import Profiles geometrically    64
// these flags specify how the geographic origin is mapped into BricsCAD, exclusively, only 1 of these values can be used :
128  import to global origin (BricsCAD = WCS matches IFC Global Coordinate system
256  import to origin of the project = BricsCAD WCS matches IFC Project Location
512  import to origin of the site = BricsCAD WCS matches IFC Site Location
Return
T, if the IFC file is successfully created, or NILotherwise
Example
(bim:ifc-exportFile "D:/Test.ifc" (+ 1 2 4 16))    creates IFC2x3 file, including entities on frozen + off layers
(bim:ifc-exportFile "D:/Test.ifc" (+ 1 4 32))        creates IC4 file, excludes  entities on frozen + off layers
Remarks
©  Bricsys NV. All rights reserved.
