bim:pset-set-property
(bim:pset-set-property ename
propertyset name value)
This function assigns the specified
value for the
property name (of PropertySet propertyset) for entity
ename.
Arguments
ename (ename) the entity to assign the property
value
propertyset (string) the PropertySet name (as Name or Label,
case-insensitive);
if the propertyset does not exist yet, it is
automatically created under "User" NameSpace, as "visible"
and
name (string) the name of the Property (as Name or Label,
case-insensitive) to assign the value for;
if the Property does not exist yet, it is
automatically created in the specified PropertySet, as "visible"
and "per-instance"
value (any
Lisp value) the value to be assigned
Return
T or NIL
Example
(bim:pset-set-property ent
"MyPropertySet" "MouTag" "abc") T
(bim:pset-get-property ent "MyPropertySet"
"MouTag") "abc"
Remarks
both PropertySet
propertyset and
Property name are automatically created (visible,
per-instance)
the Property name is
case-insensitive;
the PropertySet name/label is
case-insensitive;
all PropertyNameSpaces are automatically used
to find the specified PropertySet
