allow_accept
The applicable values for allow_accept attribute are true or false, the default value being false. When the attribute value is true, hitting Enter when the tile has focus or double-clicking will trigger the default button of the dcl dialog. A value of false will avoid triggering the default dialog button. Using the attribute with other tiles will have no effect.
related tiles
The following tiles can have an allow_accept attribute: edit_box, image_button and list_box.
