A DCL list_box component represents a list of text lines with
single or multiple selection. A list_box can be clicked in
combination with CTRL and/or SHIFT to manipulate its selection. A
list_box can be single-column or multi-column. In a multi-column
list_box an entire row is always selected, it is not possible to
select individual cells. To manipulate selection, cursor keys can
be used, also in combination with CTRL and/or SHIFT. Also,
character keys can be used to cycle through the rows that begin
with that particular character.
In BricsCAD an genuine multi-column control is used. As a result it
is possible to have resizable columns and real column labels.
BricsCAD tries to detect single-line column labels in the label
attribute of legacy dcl code. To specify single- or multi-line
column labels, the bcad_label attribute can be used.
A list_box is a child tile.
related attributes
These attributes are predefined for a list_box only:
bcad_label
This attribute specifies the column
labels of a multi-column list_box. Column labels are to be
separated by tab "\t". Within a column label, newlines "\n" may
appear to specify a multi-line column label.
The bricscad dcl engine can also detect column labels from the
label attribute. It is more complex to split the label attribute in
column labels since that method has to "degrade gracefully" on
other dcl engines, which do not support column labels. If both the
label and bcad_label attribute are specified, bcad_label will be
used instead of label. When using the bcad_label attribute, the
plain label attribute can be specified as an alternative on other
dcl engines.
When a complex alternative to multiline column labels is used
outside the list_box, for instance two rows of text_part
components, the attribute bcad_skip_next_child can be used to
suppress the complex alternative on bricscad. Instead, in bricscad,
the superior bcad_label can be used for actual multiline column
labels.
To make a list_box multi-column, see the tabs and tab_truncate
attributes.
This attribute controls the monospaced
font used when fixed_width_font attribute is enabled.
multiple_select
This attribute controls whether the
list_box is multiple select or single select. The default value is
single select.
These attributes are predefined for a list_box or popup_list
only:
list
With this attribute, the initial
contents of the list_box can be specified. To separate between
rows, use the newline symbol "\n". To separate between columns use
the tab symbol "\t". To change the contents of the list_box at
runtime, use the functions start_list, add_list, end_list.
tabs
This attribute can be used to control
the width of columns. The value of this attribute has to be a
string containing a space separated list of integers. For historic
reasons these integers are cumulative, it is a list of increasing
integers. Every integer adds the width of the next column to the
previous cumulative width. So to specify four columns of width 5,
use "5 10 15 20". Mind that there will be a fifth column of
remaining width, so perhaps the last integer is not wanted. When
DCL was first created, an actual multi-column control was not
available. Tab-stops were used rather than real columns. Tab-stops
are indeed typically defined as cumulative values.
tab_truncate
Normally text that is too wide to fit
in a column, will be spread across multiple columns and push
further any text that appears further in the same row. If this
attribute is set to true, text will be restricted to its own column
only and grid lines will be displayed between the columns and rows.
Truncated text can be revealed by dragging the grid lines between
the columns. (Dragging the columns grid lines is a BricsCAD only
feature.)
This attribute is predefined only for an image_button, edit_box
or list_box:
When a list_box has the attribute
allow_accept with value true, hitting enter when the list_box has
focus or double clicking the list_box will trigger the default
button of the dcl dialog.
This attribute is predefined only for a text, text_part,
edit_box, list_box or popup_list:
fixed_width_font
If a different monospaced font is
desired when fixed_width_font attribute is enabled, use bcad_font
attribute.
These attributes are predefined for every child tile and
consequently for a list_box as well:
mnemonic
is_tab_stop
These attributes are predefined for every tile and consequently
key
value
The value of a list_box represents its
current selection. For a single-selection list_box, the value will
be the index of the currently selected row or an empty string if no
row is selected. For a multiple-selection list_box, the value is a
space separated list of row indices.
tooltip
label
In DCL, for historic reasons, the
label attribute is typically used to fake column labels. By
inserting additional spaces, words are aligned with the columns.
For instance, say the tabs attribute has value "10 20 30", with the
intention of specifying 3 columns of width 10. A typical label
specifying column headers is of the form "header
1 header
2 header 3". Alternatively the same
value for the tabs attribute could be to specify 4 columns, 3 of
width 10, one of the remaining width. In that case a typical label
attribute would be of the form "header
1 header
2 header
3 header 4".
In BricsCAD it is possible to have actual column labels. When the
column labels are aligned with the columns using spaces, BricsCAD
attempts to parse the column headers as follows: For each column
width n, take the next n characters of the label attribute
including any trailing spaces. For the preceeding example, the
first 10 characters of the label are "header 1 ".
Including the trailing spaces gives "header
1 ". Repeating this process properly
divides the label attribute in sub-labels. If the number of
sub-labels matches the number of width in the tabs attribute (same
amount or one additional column allowed), then actual column labels
will be displayed. If actual column labels are displayed, grid
lines will be displayed, like when tab_truncate is on.
The division in sub labels by means of the label attribute is
rather elaborate. It is more easy to use the bricscad-only
attribute bcad_label, with separation in sub labels by means of the
tab "\t" symbol. However, the detection of sub labels in the label
attribute yields a good chance to "automagically" have real column
labels in bricscad when using legacy dcl code.
When changing the list_box selection
by use of the cursor keys or mouse or when hitting enter, a
callback with reason CBR_SELECT will be triggered.
When double clicking a list_box, a
callback with reason CBR_DOUBLE_CLICK will be triggered.
When a list_box has the allow_accept attribute, a
callback will be triggered with the ok button as sender by hitting
enter when the image_button has focus or by double clicking the
image_button. If no ok button has been defined, done_dialog will be
called. The ok button callback happens in addition to the normal
CBR_SELECT or CBR_DOUBLE_CLICK callback of the list_box.
