The attribute bcad_height is a BricsCAD-only attribute. If it is
specified, it is used instead of the attribute height to set a minimum height on
any tile. This allows to bypass small cosmetic problems in the
BricsCAD dcl engine. Since the BricsCAD dcl engine is implemented
with wxWidgets, some small visual differences with an MFC based dcl
engine cannot be avoided. This is however rarely needed and
normally concerns details only.
related tiles
Most tiles can have a bcad_height
attribute. It is ignored for a popup_list only.
