layerstate-addlayers
(layerstate-addlayers layerState
layerDef [ layerDef ... ] ))
This function adds 1 or more layers, with
their intended settings, to the layer state layerState.
Arguments
layerState
(string) name of the LayerState to add
the specified layers to
layerDef (list) layer definition to be added to the
LayerState
layerDef is
a list of (layerName status color linetype lineweight plotstyle)
layerName : (string) name of the layer to
add
status : (integer) combined from bit flags -
1=Off 2=Frozen 4=Locked 8=NoPlot
16=FrozenInNewVPort
color : (dotted pair) color definition, either
(62 . <IndexColor>) or (420 . <TrueColor>)
lineweight : (integer) one of the valid
LineWeight values
plotstyle : (string) name of the
plotstyle
any value can be specified as NIL - then the
default value is used (current drawing value)
Return
T if successfully added, NIL
otherwise
Example
"myLayerState"
(list "Window" 4 '(62 . 2) "Dashed" 10
"Color_2")
(list "Roof" 5 '(420 . 1420266)
"Continuous" 20 nil)
adds 2 layers to the LayerState
Remarks
