tin:setminorcontourscolor
(tin:setminorcontourscolor tinEname colorIndex)
This function assigns the colorIndex of the minor contour lines for the tinEname TinSurface entity.
Arguments
tinEname  (ename or vla-object)  the TinSurface entity to query
colorIndex  (integer 0...255)  the color index to be assigned for the minor contour lines
Return
T or NIL
Example
(tin:setminorcontourscolor tin 4)  T
Remarks
see (tin:getminorcontourscolor) function
©  Bricsys NV. All rights reserved.
