Since V21, BricsCAD LISP
provides a dedicated interface for the TinSurface + Civil
functionality (requires "Professional"
license).
This new API part is designed for simplicity,
flexibility and following the usual AutoLISP logic in naming,
arguments, behaviour and results.
As TinSurface + Civil functionality requires
the BricsCAD Professional ("PRO") license level, using a
lower-level license (or when disabled i.e. by RunAsLevel=0), the
API module is not active, and all TinSurface LISP API functions
will work in a "no-operation" mode.
As TinSurface + Civil development constantly
continues, the BRX and LISP APIs will also expand, provide more
functionality and also incorporate the ideas and feedback from
third party developers.
How to verify the License Level ?
There are 2 Lisp functions
available : (bcad$LicenseLevels) and (vle-licenselevel),
which both use identical implementation.
If TinSurface is available, the returned list
will contain the string "Professional".
"RunAsLevel" setting is also respected in
result list.
How to activate the TinSurface LISP API ?
As the LISP function set for
TinSurface + Civil is implemented using the BRX core system, it is
required to explicitly load / activate the TinSurface + Civil LISP
interface functions (somewhat similar to required (vl-load-com)
under AutoCAD AutoLISP) using :
If all context conditions
(Professional licenses) are met, it will load the extension and
return T (or NIL if the TinSurface/Civil API part is not
available).
Some general hints & rules
"entity name"
usage : in all cases, when a functions
requires an "entity name", both "classic ename" and "vla object"
are always valid and supported.
The TinSurface + Civil API covers the
following functional areas :
