vl-member-if-not
(vl-member-if-not comparator lst)
This function returns a list, starting with
first item in lst which does not match the comparator function.
Arguments |
comparator
(symbol, function, lambda) function used
for the boolean comparison; must return NIL resp.
non-NIL |
Return |
list of all items, starting with the first item which does not match the comparator function; if all list item match the comparator, NIL is returned |
Example |
(vl-member-if-not '(lambda
(x) (< x 5)) '(1 2 3 4 5 6 7 8 9 10)) |
Remarks |
validation of each list item stops at the first item, which does not match the comparator function (that is, the comparator function returns NIL), and returns the remainder of the list, from that item |
