vl-member-if
(vl-member-if comparator lst)
This function returns a list, starting with
first item in lst which matches the comparator function.
Arguments |
comparator
(symbol, function, lambda) function used
for the boolean comparison; must return NIL resp.
non-NIL |
Return |
list of all items, starting with the first item which matches the comparator function; if no list item matches the comparator, NIL is returned |
Example |
(vl-member-if '(lambda (x)
(> x 5)) '(1 2 3 4 5 6 7 8 9 10)) |
Remarks |
validation of each list item stops at the first item, which matches the comparator function (that is, the comparator function returns non-NIL), and returns the remainder of the list, from that item |
