vlr-depclone-reactor
(vlr-deepclone-reactor customData
callbackList)
This function creates and attaches a DeepClone
operation reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-beginDeepClone
a deepclone operation (inside
same database) is about to start
:vlr-endDeepClone
a deepclone operation has
ended
:vlr-abortDeepClone
been aborted
:vlr-beginDeepCloneXlation
after plain object cloning,
any object is being translated for the target database;
this event indicates the start of the
translation stage
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
deepclone reactor object -
#<VLR-DeepClone-Reactor>
args : (list)
contains 0...1 more arguments, depending on the particular event
:vlr-beginDeepClone
:vlr-endDeepClone
:vlr-abortDeepClone
0 arguments
1 argument
(integer)
represents the error status of first cloning
stage
Return
the reactor object
#<VLR-DeepClone-Reactor> or NIL
Example
Remarks
