vlr-docmanager-reactor
(vlr-docmanager-reactor customData
callbackList)
This function creates and attaches a
DocManager operation reactor to the current drawing, for the
document events specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-documentCreated
the new document was
created
:vlr-documentToBeDestroyed
the document is about to be
destroyed
:vlr-documentLockModeWillChange
the lock mode of the drawing
is about to be changed
:vlr-documentLockModeChangeVetoed
the lock mode change was
vetoed (i.e. a command to be started was cancelled)
:vlr-documentLockModeChanged
was changed
:vlr-documentBecameCurrent
the drawing became the
current drawing
:vlr-documentToBeActivated
the drawing is about to be
activated
:vlr-documentToBeDeactivated
deactivated
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
DocManager reactor object -
#<VLR-DocManager-Reactor>
args : (list)
contains 1 or more arguments depending on the particular event
1 argument
- the drawing being affected by these events
(VLA-Object)
2 arguments
(VLA-Object)
- the command name (string, global name) which
caused the locking request
5 arguments
(VLA-Object)
- integer, specifies the actual lock mode
1 = auto-write lock
2 = not locked
4 = shared-write
8 = read
10 = exclusive-write
- integer, specifies the lock
mode to be changed to:(see above)
- integer, the summarised locking mode (from
all actual contexts)
caused the locking request;
for an unlocking request, the global command
name uses a "#" prefix
Return
the reactor object
#<VLR-DocManager-Reactor> or NIL
Example
Remarks
Note :
"documentToBeActivated" and "documentToBeDeactivated" are *NOT*
related to the "current" status of a drawing, but strictly to the
"window" status, being focused or not !!
This is a widely spread misunderstanding
