vlr-dwg-reactor
(vlr-dwg-reactor customData
callbackList)
This function creates and attaches a DWG
operation reactor, for the drawing events specified by
callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
vlr-beginDwgOpen
a drawing file is about to be
opened
:vlr-endDwgOpen
a drawing file open operation
has ended
:vlr-beginClose
closed
:vlr-dwgFileOpened
a drawing file has been
loaded into CAD editor
:vlr-databaseConstructed
a drawing database has been
created
:vlr-databaseToBeDestroyed
a drawing database is about
to be destroyed
vlr-beginSave
saved
vlr-saveComplete
saved
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the dwg
reactor object - #<VLR-Dwg-Reactor>
args : (list)
contains 0...2 arguments, depending on the particular event
:vlr-beginClose
0 arguments
:vlr-beginDwgOpen
:vlr-endDwgOpen
:vlr-dwgFileOpened
1 argument
(string)
identifies the dwg file being in open
operation
:vlr-beginSave
2 arguments
1st argument : database object
2nd argument : string, dwg file name intended
for saving (can be changed by user)
:vlr-saveComplete
2 arguments
2nd argument : string, dwg file name used for
saving
Return
the reactor object
#<VLR-Dwg-Reactor>, or NIL
Example
Remarks
