vlr-dxf-reactor
(vlr-dxf-reactor customData
callbackList)
This function creates and attaches a DXF
operation reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-beginDxfIn
DXF In operation is about to
start
:vlr-dxfInComplete
DXF In operation is
completed
:vlr-beginDxfOut
DXF Out operation is about to
start
:vlr-dxfOutComplete
completed
:vlr-abortDxfIn
DXF In operation has been
aborted
:vlr-abortDxfOut
DXF out operation has been
aborted
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the dxf
reactor object - #<VLR-Dxf-Reactor>
args : (list)
contains 0 arguments (NIL):
:vlr-beginDxfIn
:vlr-dxfInComplete
:vlr-beginDxfOut
:vlr-dxfOutComplete
:vlr-abortDxfIn
:vlr-abortDxfOut
0 arguments
Return
the reactor object
#<VLR-Dxf-Reactor> or NIL
Example
Remarks
