bim:delete-material
(bim:delete-material name [ global
Removes the specified BIM material from the
document library (default), or from the global library.
Arguments |
name (string) the case-sensitive name of the material to
be deleted |
Return |
T if the material is successfully removed, NIL otherwise |
Example |
Remarks |
as long as the specified
material is used by any BIM Composition, or otherwise referenced,
deleting the material will fail; |
