bim:ifc-exportfile
(bim:ifc-exportfile  filename  [ options  [ entities ]])
This function exports all or specified entities as IFC file.
Arguments
filename  (string) the name of the IFC file to be created
options  (integer) export options flags (combination of bit values); if omitted or 0, default IFC export options (see Settings) are used
1  export BaseQuantities
2  export entities on frozen & off layers
4  explode external references
8  export MultiPlies as aggregated objects
// these flags specify the target IFC version, exclusively, only 1 of these values can be used :
16  IFC2x3
32  IFC4
48  IFC4x1
entities  (list) optional, list of ENAMEs, specifies the entities to be exported; if omitted or NIL, all entities are exported
Return
T, if the IFC file is successfully created, or NILotherwise
Example
(bim:ifc-exportFile "D:/Test.ifc" (+ 1 2 4 16))    creates IFC2x3 file, including entities on frozen + off layers
(bim:ifc-exportFile "D:/Test.ifc" (+ 1 4 32))        creates IC4 file, excludes  entities on frozen + off layers
Remarks
©  Bricsys NV. All rights reserved.
