bim:ifc-importfile
(bim:ifc-importfile filename [
options ])
This function imports the specified IFC file
into the current drawing.
Arguments
filename (string) the name of the IFC file to be
imported
options (integer) import options flags (combination of bit
values); if omitted or 0, default IFC import options (see Settings)
are used
1 import Bim Data
2 import IFC Space
4 import Parametric
Components
8 import Project Structure as
Xrefs
16 import Brep Geometry as
Meshes
32 import using SubDMesh
entities
64 import Profiles geometrically
64
// these flags specify how the geographic
origin is mapped into BricsCAD, exclusively, only 1 of these values
can be used :
128 import to global origin (BricsCAD =
WCS matches IFC Global Coordinate system
256 import to origin of the project =
BricsCAD WCS matches IFC Project Location
512 import to origin of the site =
BricsCAD WCS matches IFC Site Location
Return
T, if the IFC file is
successfully created, or NILotherwise
Example
(bim:ifc-exportFile
"D:/Test.ifc" (+ 1 2 4 16)) creates IFC2x3 file,
including entities on frozen + off layers
(bim:ifc-exportFile "D:/Test.ifc" (+ 1 4 32))
creates IC4 file, excludes
Remarks
