bim:save-material
(bim:save-material name data [
global ])
This function saves the material definition
under the specified material name, in the document library
(default), or in the global library.
Arguments
name (string) the case-sensitive name of the material to
be saved (priority over the material name as specified in data
list)
data (assoc
list) the material parameters list in the format as returned by
the (bim:get-material) function
global (optional, default NIL) if 'global' is specified and
non-NIL, the material is saved in the global database, otherwise
saved in the document-specific
library
Return
T if the save operation was
successful, NIL otherwise
Example
(setq data (bim:get-material
"Gold"))
(("Name" . "Gold") ("Desc" . "") ("Comment" .
"") ("Appearance" . "Gold") ("CH_Name" . "ANSI31") ("CH_Scale" .
1.0) ("CH_Angle" . 0.0) ("CH_Cross" . 0) ("CH_Anno" . 0) ("CH_Type"
. 1) ("SH_Name" . "SOLID") ("SH_Scale" . 1.0) ("SH_Angle" . 0.0)
("SH_Cross" . 0) ("SH_Anno" . 0) ("SH_Type" . 1))
(setq data (subst (cons "CH_Scale" 2.0) (assoc
"CH_Scale" data) data))
2.0) ("CH_Angle" . 0.0) ("CH_Cross" . 0) ("CH_Anno" . 0) ("CH_Type"
(bim:save-material "Gold_2" data)
T
Remarks
the structure of the
data list must be
the same as retrieved by the (bim:get-material) function;
the specified name has priority over the name
as specified in ("Name" . name);
the material name and all parameter values are
case-sensitive !
