bim:set-spacerepresentation
(bim:set-spacerepresentation entity
mode)
Assigns the space representation
mode of the
specified BIM "Space" entity.
Arguments |
entity any entity (as normal entity or as VLA object name)
to set the representation mode for (if it is a BIM "Space"
entity) |
Return |
T if successful or NIL, if not a "Space" entity |
Example |
(bim:set-spacerepresentation ent bcBimSpaceStyleFootprint) T |
Remarks |
a newly created space uses
bcBimSpaceStyleSolid as default representation mode; |
© Bricsys NV. All rights reserved. |
