dos_command
(dos_command command
[mode])
Runs the specified OS command (like when
starting from a DOS box or terminal box.
command :is a
string specifying the OS command including all
parameters
mode :is an
integer to control the behaviour of the OS shell box :
0
show the shell window in
normal (last-used) mode
1
normal (last-used) mode, but is not activated
2
minimised, but inactive state
3
minimised, and active state
4
maximised state
Returns the string executed in OS command
shell, or NIL in case of an error.
Examples :
(dos_command "notepad.exe" 1)
runs Notepad.exe with normal shell box
(dos_command "notepad.exe" 3)
runs Notepad.exe with minimised shell box
(dos_command "services.msc" 1)
runs control panel with normal shell box
(dos_command "services.msc" 3)
runs control panel with minimised shell box
