fixed_height
When fixed_height is applied to the
DCL dialog root item (the "dialog" entry) and set to false, the entire DCL
dialog becomes resizable.
For a resizable DCL dialog, all tiles are
automatically scaled resp. positioned to provide a smooth and
visually correct appearance.
This is a BricsCAD only feature, but it won't
disturb usage of the DCL dialog in other CAD
applications.
By design of DCL, it is permitted to add any
custom attribute; custom attributes simply have no effect, apart
from the possibility to fetch them using the get_attr function.
special behaviour applies :
when fixed_height is applied to the
dialog root
