mech:constraint-set-name
(mech:constraint-set-name  constraint  name)
Assigns the new name (string) to the specified constraint (integer).
Arguments
constraint (integer) the constraint to modify
name (string) the new name for the constraint
Return
T on success or NIL on failure
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: a40c9010>
(setq grp (mech:get-constraintsgroup blkId))  2685508064
(setq constraints (mech:get-constraints grp))  (2685508640 2685507680)
(setq constraint (nth 0 constraints))  2685508640
(mech:constraint-set-name constraint "Dinstance_Ortho")  T
Remarks
Note
©  Bricsys NV. All rights reserved.
