mech:constraint-set-placement
(mech:constraint-set-placement  constraint  argIndex  mode)
Defines the placement mode (integer 0-3) for the specified constraint (integer) at the argument index argIndex (integer, 0/1.
Arguments
constraint (integer) the constraint to modify
argIndex (integer) 0 or 1, refering to the first or second definition entity
mode (integer) one of the 3DConstraints Placement values
Return
T on success or NIL on failure
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: a40c9010>
(setq grp (mech:get-constraintsgroup blkId))  2685508064
(setq constraints (mech:get-constraints grp))  (2685508640 2685507680)
(setq constraint (nth 0 constraints))  2685508640
(mech:constraint-set-placement constraint 0 bc3dcPlacementAny)  T
Remarks
not all constraint types support all placement modes (or do not support placement mode at all)
Note
©  Bricsys NV. All rights reserved.
