mech:parameters-set-exposemode
(mech:parameters-set-exposemode  parameter  mode)
Assigns a new expose mode (integer, Off=0, On=1, Undefined=2) to the specified parameter (integer).
Arguments
parameter (integer) the parameter identifier to be modified
mode (integer 0...2) the new expose mode value for the parameter
Return
T if successful, or NIL otherwise
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: 4aaa68b0>
(setq param (mech:parameters-get-byname blkId "Length"))  971708080
(mech:parameters-set-exposemode param bc3dcExposeOn)  T
Remarks
for the 'Expose Mode' value, see 3DC Parameters Expose Mode
Note
©  Bricsys NV. All rights reserved.
