mech:parameters-set-expression
(mech:parameters-set-expression
parameter expression)
Assigns a new expression (string) to the
specified parameter (integer).
Arguments |
parameter (integer) the parameter identifier to be
modified |
Return |
T if successful, or NIL otherwise |
Example |
(vl-load-mech)
2 |
Remarks |
Note |
© Bricsys NV. All rights reserved. |
