mech:parameters-set-unitstype
(mech:parameters-set-unitstype parameter
unitsType)
Assigns a new units unitsType mode (integer,
None=0, Length=1, Area=2, Volume=3) to the specified
parameter (integer).
Arguments |
parameter (integer) the parameter identifier to be
modified |
Return |
T if successful, or NIL otherwise |
Example |
(vl-load-mech)
2 |
Remarks |
for the 'Units Type' value, see 3DC Parameters Units Type |
Note |
© Bricsys NV. All rights reserved. |
