mech:parameters-set-name
(mech:parameters-set-name  parameter  name)
Assigns a new name (string) to the specified parameter (integer).
Arguments
parameter (integer) the parameter identifier to be modified
name (string) the new name of the parameter
Return
T if successful, or NIL otherwise
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: 4aaa68b0>
(setq param (mech:parameters-get-byname blkId "Length"))  971708080
(mech:parameters-set-name param "Radius_X")  T
Remarks
Note
©  Bricsys NV. All rights reserved.
