tab_truncate
Normally, any text that is too wide to fit in
a column, will be spread across multiple columns and pushes any
text which appears to the right further in the same row, sometimes
providing very inconvenient visual effects and
artefacts.
If tab_truncate attribute is set
to true,
text will be restricted to its own column only and grid lines will
be displayed between the columns and rows; using
false provides
standard behaviour.
Truncated text can be revealed by dragging the
grid lines between the columns - dragging the column grid lines is
a BricsCAD only feature.
Combined with the special label handling for listboxes (having true column headers), a 'normal' DCL
listbox becomes very comfortable.
special behaviour applies :
listboxes only, otherwise ignored
