tingr:set-regionstart
(tingr:set-regionstart  grading  param)
Assigns the param region start parameter for the grading TinGrading entity.
Arguments
grading  (ename or vla-object) the TinGrading entity
param  (number, integer or double)  the grading start parameter
Return
T or NIL
Example
Remarks
see (tingr:get-regionstart) function
©  Bricsys NV. All rights reserved.
