tingr:set-segmentmaxangle
(tingr:set-segmentmaxangle  grading  maxang)
Assigns the maxang maximum segment angle deviation to be used by the grading TinGrading entity.
Arguments
grading  (ename or vla-object) the TinGrading entity
maxang  (number, integer or double)  maximum segment angle deviation to be used
Return
T or NIL
Example
Remarks
see (tingr:get-segmentmaxangle) function
©  Bricsys NV. All rights reserved.
