vl-exit-with-value
(vl-exit-with-value value)
This function returns value to the function calling the actual "separate NameSpace" function.
Arguments
value  (any Lisp value or expression)
Return
returns value
Example
Remarks
this function stops the Lisp execution of the actual "separate NameSpace" (except, if a (vl-catch-all-apply) error trap is active;
when called from current document NameSpace, Lisp processing is cancelled with an error message
©  Bricsys NV. All rights reserved.
