vl-file-copy
(vl-file-copy srcFile dstFile [ doAppend ]
This function copies the content of
srcFile into dstFile.
Arguments |
srcFile (string) name of the source file to be
copied |
Return |
(integer) number of bytes copied from srcFile; -1 if an error happened |
Example |
Remarks |
if no path is specified for the file name, the file is searched in actual OS folder; the file copy operation also supports binary file content (not only text files) |
© Bricsys NV. All rights reserved. |
