vl-layerstates-save
(vl-layerstates-save  lstate  [bitFlags  [VportEname]])
saves the current layer set as LayerState 'lstate', optionally specifying the 'bitFlags' to be assigned to the LayerState and the VPort specific layer  settings, if 'VportEname' is specified as non-NIL
Arguments
lstate  a string or symbol specifying the LayerState
bitFlags  control bit combination (integer) to be assigned (or NIL)
VportEname  entity name specifying the intended viewport (or NIL)
Return
T if successful, NIL to indicate an error
Example
(vl-layerstates-save "MyLayers_Frozen+Locked" 6)
Remarks
for 'bitFlags' argument, see (vl-layerstates-setpropertymask)
this is a BricsCAD-specific function !
©  Bricsys NV. All rights reserved.
