vl-unload-vlx
(vl-unload-vlx appName)
This function removes all function definitions of a loaded NameSpace-enabled application appName.
Arguments
appName  (string) the name of a VLX compiled application
Return
T is all functions from appName were successfully removed (set as NIL)
Example
Remarks
the "application name" is the file name without path and extension;
for a normally loaded Lisp file, this function does nothing
©  Bricsys NV. All rights reserved.
