vl-vbaload
(vl-vbaload fileName)
This function loads the VBA application file (.dvb).
Arguments
fileName  (string) the VBA application file
Return
(string) fileName if successful, NIL otherwise
Example
Remarks
the fileName can optionally contain the absolute or relative path specification, also the optionally .dvb extension;
if no path is specified, or a relative path only, the normal search logic is used (like (findfile) function)
©  Bricsys NV. All rights reserved.
