vl-vplayer-set-color
(vl-vplayer-set-color  layer  viewport  color)
This function sets the viewport-specific color override for the layer;
(layer can specify one or more layers)
Arguments
layer  specifies one or more layer(s) to apply the viewport-specific color
can be :
1. name  (string)  the name of 1 layer
2. ename  (ename)  the entity name of the layer
3. enameList  (list of name | ename)  list of 1 or more layer entity string names and/or enames
viewport  specifies one or more viewport
can be
1. ename  (ename) the viewport's entity name
2. cvport  (integer)  the viewport's CVPORT viewport number
3. (list ename cvport ...)  list ename(s) and/or cvport(s)
color  (integer)  the index color value to be assigned; if NIL, any color override is removed
Return
T if the color value is successfully applied resp. removed, NIL otherwise
Example
Remarks
©  Bricsys NV. All rights reserved.
