vl-vplayer-set-truecolor
(vl-vplayer-set-truecolor layer
viewport rgbColor)
This function sets the viewport-specific
rgbColor truecolor
override for the layer;
(layer
can specify one or more layers)
Arguments |
layer specifies one or more layer(s) to apply the
viewport-specific truecolor |
Return |
T if the truecolor value is successfully applied resp. removed, NIL otherwise |
Example |
Remarks |
