vl-vplayer-set-transparency
(vl-vplayer-set-transparency  layer  viewport  transparency)
This function sets the viewport-specific transparency override for the layer.
(layer can specify one or more layers)
Arguments
layer  specifies one or more layer(s) to apply the viewport-specific transparency
can be :
1. name  (string)  the name of 1 layer
2. ename  (ename)  the entity name of the layer
3. enameList  (list of name | ename)  list of 1 or more layer entity string names and/or enames
viewport  specifies one or more viewport
can be
1. ename  (ename) the viewport's entity name
2. cvport  (integer)  the viewport's CVPORT viewport number
3. (list ename cvport ...)  list ename(s) and/or cvport(s)
transparency  (integer or double)  the transparency value to be assigned; if NIL, any transparency override is removed
can be
1. integer  0...255
2. double  0...1.0
Return
T if the transparency value is successfully applied, NIL otherwise
Example
Remarks
this is a BricsCAD-specific function !
©  Bricsys NV. All rights reserved.
