vlax-safearray-get-element
(vlax-safearray-get-element saVar index1 [ index2 [ index3 ... ] ] ] )
This function returns the value of saVar SafeArray at the index specified by index1, index2, index3 ...
Arguments
saVar  (SafeArray) the SafeArray to retrieve the indexed value from
index1  (integer)  the index for the first dimension
index2  (integer, optional)  the index for the second dimension
index3  (integer, optional)  the index for the third dimension
Return
the specified array value (plain Lisp or COM data item)
Example
(setq sa (vlax-make-safearray vlax-vbDouble '(0 . 1) '(0 . 2)))  #<safearray...>
(vlax-safearray-fill sa '((1.0 2.0 3.0) (10.0 11.0 12.0)))  #<safearray...>
(vlax-safearray-get-element sa 0 0)  1.0
(vlax-safearray-get-element sa 0 1)  2.0
(vlax-safearray-get-element sa 0 2)  3.0
(vlax-safearray-get-element sa 1 0)  10.0
(vlax-safearray-get-element sa 1 1)  11.0
(vlax-safearray-get-element sa 1 2)  12.0
Remarks
see (vlax-make-safearray) function
©  Bricsys NV. All rights reserved.
