vlr-dwg-reactor
(vlr-dwg-reactor customData callbackList)
This function creates and attaches a DWG operation reactor, for the drawing events specified by callbackList.
Arguments
customData  (any valid Lisp data) custom data to be associated with the reactor object, can be NIL
callbackList  (list)  list of DottedPair entries, each DottedPair has the form
(event . callback)
event : one of these symbolic constants
vlr-beginDwgOpen
a drawing file is about to be opened
:vlr-endDwgOpen
a drawing file open operation has ended
:vlr-beginClose
a drawing file is about to be closed
:vlr-dwgFileOpened
a drawing file has been loaded into CAD editor
:vlr-databaseConstructed
a drawing database has been created
:vlr-databaseToBeDestroyed
a drawing database is about to be destroyed
vlr-beginSave
a drawing file is about to be saved
vlr-saveComplete
a drawing file has been saved
callback : the client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args / ...) ...)
reactor : the dwg reactor object - #<VLR-Dwg-Reactor>
args : (list) contains 0...2 arguments, depending on the particular event :
:vlr-beginClose
0 arguments
:vlr-beginDwgOpen
:vlr-endDwgOpen
:vlr-dwgFileOpened
1 argument (string)
identifies the dwg file being in open operation
:vlr-beginSave
2 arguments
1st argument : database object
2nd argument : string, dwg file name intended for saving (can be changed by user)
:vlr-saveComplete
2 arguments
2nd argument : string, dwg file name used for saving
Return
the reactor object #<VLR-Dwg-Reactor>, or NIL
Example
Remarks
©  Bricsys NV. All rights reserved.
