vlr-dxf-reactor
(vlr-dxf-reactor customData callbackList)
This function creates and attaches a DXF operation reactor to the current drawing, for the command events specified by callbackList.
Arguments
customData  (any valid Lisp data) custom data to be associated with the reactor object, can be NIL
callbackList  (list)  list of DottedPair entries, each DottedPair has the form
(event . callback)
event : one of these symbolic constants
:vlr-beginDxfIn
DXF In operation is about to start
:vlr-dxfInComplete
DXF In operation is completed
:vlr-beginDxfOut
DXF Out operation is about to start
:vlr-dxfOutComplete
DXF Out operation is completed
:vlr-abortDxfIn
DXF In operation has been aborted
:vlr-abortDxfOut
DXF out operation has been aborted
callback : the client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args / ...) ...)
reactor : the dxf reactor object - #<VLR-Dxf-Reactor>
args : (list) contains 0 arguments (NIL):
:vlr-beginDxfIn
:vlr-dxfInComplete
:vlr-beginDxfOut
:vlr-dxfOutComplete
:vlr-abortDxfIn
:vlr-abortDxfOut
0 arguments
Return
the reactor object #<VLR-Dxf-Reactor> or NIL
Example
Remarks
©  Bricsys NV. All rights reserved.
