vlr-editor-reactor
(vlr-editor-reactor customData
callbackList)
This function creates and attaches a Editor
operation reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:vlr-beginClose
the drawing is about to be
closed
:vlr-beginDxfIn
a DXF In operation is about
to start
:vlr-abortDxfIn
a DXF In operation has been
aborted (failed)
:vlr-dxfInComplete
completed
:vlr-beginDxfOut
a DXF Out operation is about
to start
:vlr-abortDxfOut
a DXF Out operation has been
aborted (failed)
:vlr-dxfOutComplete
completed
:vlr-databaseToBeDestroyed
the drawing database is about
to be deleted
:vlr-commandWillStart
a command is about to
start
:vlr-commandEnded
a command has finished
:vlr-commandCancelled
a command was
cancelled
:vlr-commandFailed
a command has failed
completion
:vlr-unknownCommand
an unknown command was
entered
:vlr-lispWillStart
a Lisp expression is about to
be evaluated
:vlr-lispEnded
a Lisp expression evaluation
has finished
:vlr-lispCancelled
a Lisp expression
evaluation was cancelled
:vlr-beginDwgOpen
a dwg file is about to be
opened
:vlr-endDwgOpen
a dwg file has been
loaded
:vlr-dwgFileOpened
a dwg file was opened as
editor document
:vlr-beginSave
saved
:vlr-saveComplete
a dwg save operation has been
completed
:vlr-sysVarWillChange
a system variable is about to
be changed
:vlr-sysVarChanged
a system variable has been
changed
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
editor reactor object - #<VLR-Editor-Reactor>
args : (list)
contains 0-2 arguments, depending on the particular event
:vlr-lispEnded
:vlr-lispCancelled
:vlr-beginDxfIn
:vlr-dxfInComplete
:vlr-abortDxfIn
:vlr-beginDxfOut
:vlr-dxfOutComplete
:vlr-abortDxfOut
:vlr-beginClose
0 arguments
:vlr-commandEnded
:vlr-commandFailed
:vlr-unknownCommand
1 argument
(string)
the command name
:vlr-lispWillStart
1 argument
(string)
the first line of the Lisp expression to be
evaluated
:vlr-beginDwgOpen
:vlr-endDwgOpen
:vlr-dwgFileOpened
1 argument
(string)
the name of the dwg file
1 argument
(string)
the name of the system variable
:vlr-beginSave
2 arguments
1st argument : database
(VLA-Object)
2nd argument : string, intended name for the
dwg file
:vlr-saveComplete
2 arguments
(VLA-Object)
2nd argument : string, name used for saving
the dwg file
:vlr-sysVarChanged
2 arguments
1st argument : string, the name of the system
variable
2nd argument : integer 1=success,
0=failed
Return
the reactor object
#<VLR-Editor-Reactor> or NIL
Example
Remarks
