vlr-undo-reactor
(vlr-undo-reactor customData callbackList)
This function creates and attaches a Undo command reactor to the current drawing, for the command events specified by callbackList.
Arguments
customData  (any valid Lisp data) custom data to be associated with the reactor object, can be NIL
callbackList  (list)  list of DottedPair entries, each DottedPair has the form
(event . callback)
event : one of these symbolic constants
:vlr-undoSubcommandAuto
Undo option "Auto" has been processed
:vlr-undoSubcommandControl
Undo option "Control" has been processed
:vlr-undoSubcommandBegin
Undo option "Begin" (or "Group") is about to be processed
:vlr-undoSubcommandEnd
Undo option "End" is about to be processed
:vlr-undoSubcommandMark
Undo option "Mark" is about to be processed
:vlr-undoSubcommandBack
Undo option "Back" is about to be processed
:vlr-undoSubcommandNumber
Undo option "Number" is about to be processed
callback : the client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args / ...) ...)
reactor : the undo reactor object - #<VLR-Undo-Reactor>
args : (list) contains 1 or more arguments depending on the particular event :
1 argument (integer) status
integer value is always 0, indicates "operation is about to start"
2 arguments
1st argument : (integer) status, always 4, indicates "operation finished"
2nd argument : (symbol) T/NIL - T indicates "Auto" is ON, NIL indicates OFF
2 arguments
2nd argument : (integer) "Control" option 0=None  1=One  2=All
2 arguments
1st argument (integer) status, always 0, indicates "operation is about to start"
2nd argument (integer) number of undo staps to be undone
Return
the reactor object #<VLR-Undo-Reactor> or NIL
Example
Remarks
©  Bricsys NV. All rights reserved.
