vlr-wblock-reactor
(vlr-wblock-reactor customData
callbackList)
This function creates and Wblock a Insert
operation reactor to the current drawing, for the command events
specified by callbackList.
Arguments
customData
(any valid Lisp data) custom data to be
associated with the reactor object, can be NIL
callbackList (list) list of DottedPair entries, each
DottedPair has the form
(event
. callback)
event : one of
these symbolic constants
:VLR-wblockNotice
wblock operation is about to
start
:VLR-beginWblock
wblock operation of the
entire database is about to start
:VLR-beginWblockPt
wblock operation of an entity
set is about to start
:VLR-beginWblockId
BlockTableRecord is about to start
:VLR-otherWblock
start
:VLR-beginWblockObjects
wblock operation starts
intermediate stage of ObjectId translation
:VLR-endWblock
wblock operation has been
finished
:VLR-abortWblock
aborted
callback : the
client Lisp side callback function, using 2 arguments :
(defun MyCB ( reactor args
reactor : the
wblock reactor object - #<VLR-Wblock-Reactor>
args : (list)
contains 1 or more arguments depending on the particular event
:VLR-wblockNotice
1 argument :
source database (VLA-Object)
:VLR-endWblock
:VLR-abortWblock
1 argument :
target database (VLA-Object)
:VLR-beginWblock
:VLR-otherWblock
2 arguments
1st argument : target database
(VLA-Object)
2nd argument : source database
(VLA-Object)
2 arguments
1st argument : source database
(VLA-Object)
2nd argument : IDMapping for the objects being
cloned
:VLR-beginWblockPt
3 arguments
(VLA-Object)
(VLA-Object)
3rd argument : 3D WCS point list (base point
in target database)
:VLR-beginWblockId
3 arguments
(VLA-Object)
(VLA-Object)
3rd argument : ObjectId of the
BlockTableRecord
Return
the reactor object
#<VLR-Wblock-Reactor> or NIL
Example
Remarks
